Preview: Diewald Seahorse II
Watches and such at Kickstarter.
Postby koimaster » April 23rd 2018, 9:34am
The Seahorse II’s brushed stainless steel barrel case is 43mm wide and 48mm long with a double domed, AR coated sapphire crystal and decorated case back. It is rated for 200m water resistance and has a signed, screw down crown. Integrated, drilled lugs hold the 22mm rubber strap. The 120-click, unidirectional bezel boasts a tough and glossy ceramic insert. As before, Diewald uses a Seiko NH35 automatic, a reliable 24-jewel unit that hacks, hand winds, and moves at 21.6k bph
$233.00
http://www.thetimebum.com/2018/04/previ ... ime+Bum%29
https://www.kickstarter.com/projects/12 ... vers-watch
Re: Preview: Diewald Seahorse II
Postby Thunder1 » April 23rd 2018, 9:49am
They make some nice cordless drills, as well..
Return to Kickstarter/Crowd Funding Projects
