Hamilton Field Watch @ Mass Drop...
Postby Thunder1 » September 27th 2018, 3:31am
Seems as if both the 40mm & 42mm(+ $25) versions of the automatic Hammy Khaki Field Watch are available
Hamilton Khaki Field Automatic Watch
$429.99
Legible, 100M Water Resistant, 80-Hour Reserve
This straightforward and refined field watch from Hamilton covers all the bases. First, the brain behind the watch is a Hamilton H-10 movement with 25 jewels. Accurate and reliable, the movement offers a remarkable 80-hour power reserve, so you don’t need to wear the watch every day (even though you may want to). The military-inspired dial is super easy to read thanks to large Arabic numerals and a 24-hour ring. The hands are also lumed for added visibility, and a window tracks the date at 3 o’clock. Water resistant to 100 meters, the brushed stainless steel case is ready for inclement weather, or even a dip in the water.
Note: At checkout, choose the H70305193 or H70605163 (+ $25) model.
Specs:
Movement: Hamilton H-10 25-jewel automatic
Base: ETA C07.111
28800 vph
Case material: Stainless steel
Crystal: Sapphire
Caseback: Display
Date display
Case diameter: 40 mm
Case thickness: 11 mm
Lug width: 20 mm
Water resistance: 100 m (330 ft)
Shipping:
All orders will be shipped by the vendor.
Estimated ship date is Oct 19, 2018 PT.
After the drop ends, payment will be collected and the group’s order will be submitted to the vendor up front, making all sales final. Check the discussion page for updates on your order.
https://www.massdrop.com/buy/hamilton-k ... 4072125405
Return to Daily and Weekly Deals
