Review on The Timex T2M467
Post your watch reviews here
Postby abduksion » November 1st 2013, 4:23pm
I wanted to wait at least a month to do a review on this watch, I was past that so please forgive me. I'll be using older pics for this review because my free bandwidth on Photobucket is almost up (cheap bastards). Ok I'll make this as short and unbiased as I can, but I may say something that makes me sound like I'm some kind of Invicta butt boy fan. Now the review but first the specs.
Case
42mm
13mm (thick)
20mm lugs
Mineral crystal
100m
indiglo
There are some watches that can pull off that all polished look while others can't. Polished dive watches No polished dress watches Yes.
The Timex T series is or was considered to be Timex's high end line before the TX series was introduced back in 06? Timex as a long history of making watches at affordable prices but some see them as a cheap Wal-Mart brand. That is an understatement to me anyways sure there's your typical digital Timex watches that cost $18-30 than there's Timex analog watches that Timex actually took the time to make. This is like buying a Tudor at 1/3 of the price of a Rolex. We all know Tudor is made by Rolex but without the Rolex prices because, Tudor doesn't use Rolex movements.
I've never seen Timex as a go to brand when shopping I tend to go after brands like Citizen, Seiko, Casio etc. I had purchased this Timex at a TJ Max store and honestly wasn't looking to buy anything but saw it and said what the hell I'll give it a try. At first the style didn't sing to me and was about to return it for a refund but decided to keep it. The movement is the same as my other Timex T42351 I bought a few months back. I still have no idea what movement Timex uses in these watches. I'm still gonna say its a ETA 251.262 or a ETA 251.272? But have them assembled in the Philippians to low cost?. As I mentioned before the entire case is highly polished including the signed buckle case back is brushed. Pushers are squared shape instead of round ones which gives it a higher end look. Crown is push-pull and when press activates the Indiglo. No lume on the hands and the dial is gray according to Amazon and it has a dark brown strap. Date is at the 4 o'clock that has a reverse disk to blend into the dial. The main hr/minute hands look plastic with a frosted look? I tried to compare this watch to other models out there and came across this one by the CWC company http://www.cwcwatch.com/quartz-chronograph-new.htm. I've had this Timex on the black nato strap u guys see me wear on my Movado. The Nato band give the Timex a military look and feel and frankly it should of been the band used instead of the strap they provided. Now the pics. Sorry no side pics.
In conclusion this Timex was made for those who wanted that military inspired look, with a good size, movement and bang for the buck. If this was a Tissot, Seiko, Citizen, or even a Maurice Lacroix it would be a minimum of $1,500? Now would I recommend it? It depends if you were looking for a dress, sports or military look? This can easily be all three with the right straps. Put a black nato you have a military pilots chronograph, put a black genuine alligator strap (like I did before) and it makes it look 10x expensive. Or just keep it on the original strap. ALL in all I say you like it go for it. BTW here's similar models. http://www.amazon.com/s/ref=nb_sb_ss_i_ ... x+t+series
Senior Member
Re: Review on The Timex T2M467
Postby Horse Feathers » November 1st 2013, 4:29pm
abduksion wrote:The movement is the same as my other Timex T42351 I bought a few months back. I still have no idea what movement Timex uses in these watches. I'm still gonna say its a ETA 251.262 or a ETA 251.272?
I'm confused !
Horse Feathers
Postby abduksion » November 1st 2013, 4:35pm
I'm confused !
Timex doesn't say which movement they use but the dial configuration is the same used in ETA movements. The hour hand can be set independently to advanced the time forward or backwards like seen the ETA movements.
Senior Member
Postby conjurer » November 1st 2013, 4:45pm
Nice review, Kev. Well done.
Postby abduksion » November 1st 2013, 4:49pm
conjurer wrote:Nice review, Kev. Well done.
Thanks I appreciate it.
Senior Member
Postby foghorn » November 1st 2013, 5:07pm
Timex uses Chinese movements. Good values but certainly not powered by ETA movements.
Postby abduksion » November 1st 2013, 5:21pm
foghorn wrote:Timex uses Chinese movements. Good values but certainly not powered by ETA movements.
Thanks for clearing that up for me. I had no idea wish they would just say that on the back of the caseback?
Senior Member
Postby Horse Feathers » November 1st 2013, 10:58pm
I'm confused !
http://www.esslinger.com/eta-251-272-qu ... ments.aspx
http://www.esslinger.com/eta-251-262-qu ... ments.aspx
Horse Feathers
Postby 3Flushes » November 2nd 2013, 2:14am
Nice review Ab. They've definitely been moving in the right direction with their products the last several years. The 251.262/272 are my favorite quartz movements. I used to travel a great deal, and there is no easier movement to reset as you move through timezones. The date changes with every rotation of the hour hand past 12; a little bit of a hassle if you're several days off. I wonder if the Timex version has the same complications; the ETA's are fun movements.
abduksion wrote: Sorry no side pics.
Side pics schmide pics, but no indiglo shot?
Copyright ©️ 2018 3flushes Media.
Postby abduksion » November 2nd 2013, 5:02pm
3Flushes wrote:Nice review Ab. They've definitely been moving in the right direction with their products the last several years. The 251.262/272 are my favorite quartz movements. I used to travel a great deal, and there is no easier movement to reset as you move through timezones. The date changes with every rotation of the hour hand past 12; a little bit of a hassle if you're several days off. I wonder if the Timex version has the same complications; the ETA's are fun movements.
I would of showed a indigo shot but its very weak on the watch.
Senior Member
Return to Reviews
