Romain Gauthier - Time-Only Insight Micro-Rotor
Luxury and Independent Watch brands
Postby koimaster » March 21st 2017, 8:43am
Similar in function to the Laurent Ferrer Galet Micro-Rotor, the Insight Micro-Rotor is Romain Gauthier‘s most conventional wristwatch to date, but executed to the high standards of decoration that’s typical of the brand.
Just launched at Baselworld 2017, the Insight Micro-Rotor is decidedly traditional in colour and style compared to the Romain Gauthier’s last new launch. Measuring a manageable 39.5mm in diameter and in either gold or platinum, the case has a conventional crown for winding and time-setting at two o’clock (instead of back-winder crowns or pushers as in his earlier works).
The time display is laid out in a vertical line, with the hours and minutes at 12 o’clock, with the seconds just below. Both sub-dials for the time are covered in fired vitreous enamel, available in blue or white.
http://watchesbysjx.com/2017/03/romain- ... rotor.html
Re: Romain Gauthier - Time-Only Insight Micro-Rotor
Postby foghorn » March 21st 2017, 8:52am
I'll withhold comment until they put the dial on.
Return to Luxury & Independent Watchmakers
