Saturation Diving, Helium Valves
Postby koimaster » November 30th 2016, 11:11am
In another installment in our series on the basics of divers’ watches, we explain why some dive watches have built-in helium-release valves and why others don’t. We also explain why each type is perfectly OK, depending on the type of diving you do.
Comparing “diving” as most people know it to “saturation diving” is a bit like comparing an amateur bicyclist to a professional construction worker. They might share the same environment and the same need to breathe, but other than that, they are in fact doing quite different things (this applies to most types of diving, by the way). Saturation diving (meaning the diver’s tissues have absorbed the maximum of gas possible) was practically explored at the end of the 1930s in order to (A.) reduce a diver’s risk of decompression sickness when (B.) working at great depth for (C.) long periods of time — in other words, to increase both effectiveness and safety.
At the end of the 1950s, the necessary scientific basis was provided to begin saturation diving in the military and, soon after, to use it on a commercial basis. In short: such a diver works under water and lives in a dry, pressurized environment for up to several weeks, and is decompressed to surface pressure only once, at the end of the mission.
http://www.watchtime.com/blog/dive-watc ... e-watches/
Re: Saturation Diving, Helium Valves
Postby bedlam » November 30th 2016, 5:13pm
If you can unscrew a crown, you don't need an HEV
Postby conjurer » November 30th 2016, 5:19pm
bedlam wrote:If you can unscrew a crown, you don't need an HEV
What if you got no arms or legs??
Postby bedlam » November 30th 2016, 5:21pm
Then getting in and out of a diving bell is gonna be a bitch ;)
Postby conjurer » November 30th 2016, 5:26pm
Hater!!:
Postby Tzimisces » November 30th 2016, 5:52pm
Hater!!:
Nick? I'd have guessed his name is Bob.
Tzimisces
Postby Lost » November 30th 2016, 9:28pm
And you're a diver?
Your name is Bob?
Lost
Postby koimaster » January 26th 2018, 4:52pm
t
Postby bedlam » January 26th 2018, 8:47pm
Its a couple of years later and HEV's are still pointless.
Return to Dive Watches
