Concrete Watch
Watches and such at Kickstarter.
Concrete Watch
Postby TemerityB » August 25th 2017, 4:49pm
I ... I just will let this speak for itself. I would have thought it was the next innovation by Master Wing that you could use that mini-catapult to attack with BBs.
A watch made out of concrete may sound like a strange concept, but not the designers of a weightless new wristwatch that claims to be durable, fashionable and timeless. Will it however, stand the test of time?
The watch, called The Masonic, is a device that re-imagines concrete through meticulous design and advanced engineering — or so say its designers.
The Masonic has been actively promoted on Kickstarter, a company that helps artists, musicians, filmmakers and designers get their project funded as it sources the support they need to turn their ideas into reality.
https://sputniknews.com/science/2017082 ... ckstarter/
Re: Concrete Watch
Postby foghorn » August 25th 2017, 4:56pm
FTF'nW
Re: Concrete Watch
Postby biglove » August 25th 2017, 4:58pm
I have seen two other concrete watch designs.
One, https://www.watches.com/22-design-4th-d ... ete-watch/ and another that was actually far more expensive.
Their truly is no limit to the stupidity of watch buyers out there.
Re: Concrete Watch
Postby foghorn » August 25th 2017, 5:01pm
biglove wrote:I have seen two other concrete watch designs.
Didn't you just buy an Aggregate Terra?
Re: Concrete Watch
Postby MKTheVintageBloke » August 25th 2017, 5:02pm
Merde!
General Pierre Cambronne to General Colville at Waterloo
Re: Concrete Watch
Postby biglove » August 25th 2017, 5:09pm
I did and it dubbells as an Artifishul Testicles.
Re: Concrete Watch
Postby PiningforElgin » August 25th 2017, 5:43pm
A copy/homage/knockoff of Hublot concrete watch
PiningforElgin
Member
Re: Concrete Watch
Postby Tzimisces » August 25th 2017, 6:18pm
The one in your link is a weird design, but interesting and one in which a concrete dial makes sense artistically.
The one in the OP is just a run-of-the-mill fashion watch. There's no real point in using concrete rather than any other material.
Also we should probably be writing "concrete", since this material is not like a sidewalk or foundation. I think it's rather like any number of patching/leveling compounds.
Tzimisces
Re: Concrete Watch
Postby PiningforElgin » August 25th 2017, 6:30pm
I always assumed it was indeed the material used for paving streets. It's not? I mean street cement is a rather cheap material to get
PiningforElgin
Member
Re: Concrete Watch
Postby conjurer » August 25th 2017, 6:37pm
It's certainly cheaper than surgical grade stainless steel!!*
*This gag was posted just to piss off Hawk.
Re: Concrete Watch
Postby Tzimisces » August 25th 2017, 6:46pm
There are many types of concrete. A sidewalk might typically be a standard 3000psi mix, with #57 stone as aggregate. A few months ago we poured a foundation for a tower crane with a mix design for 9000psi concrete. The next morning it was hot...perhaps 120 degrees...as it cured. Different types of cement with various chemicals yield different properties.
Patching compounds are thin, plastic cement products that go on smooth, more like a grout. They range from the stuff you buy at Home Depot to patch a crack to specialty 3 part epoxy mixes that can be quite costly.
Tzimisces
Re: Concrete Watch
Postby PiningforElgin » August 25th 2017, 9:40pm
Great info. Thanks!
PiningforElgin
Member
Re: Concrete Watch
Postby Mortuus » August 26th 2017, 6:44am
I just got off the phone with Avi Viera, and she confirmed that Reynoddo was coming back, and, as a direct response to this vast tidal wave of cement watches looms like a tsunami over the world of horological high fashion, they have sought and been granted a patent on the world's first ever Swiss RUBBER Watch! :roll:
Okay, so I was wrong... http://thewatchforum.net/forum/index.php ...but I was never so glad to be incorrect... ;)
Re: Concrete Watch
Postby conjurer » August 26th 2017, 7:33am
Mortuus wrote:I just got off the phone with Avi Viera, and she confirmed that Reynoddo was coming back, and, as a direct response to this vast tidal wave of cement watches looms like a tsunami over the world of horological high fashion, they have sought and been granted a patent on the world's first ever Swiss RUBBER Watch! :roll:
Did you rub one out whilst chatting with Ms. Viera? I wood have!!
Re: Concrete Watch
Postby Mortuus » August 26th 2017, 7:38am
A gentleman never rubs and tells... ;)
Re: Concrete Watch
Postby apollowatches » September 13th 2017, 5:06pm
That's very unique material. Made from a proprietary cement blend.
apollowatches
Member
Re: Concrete Watch
Postby foghorn » September 13th 2017, 5:43pm
Stupid material. Made by a cement head.
Re: Concrete Watch
Postby Rusty » September 14th 2017, 7:37am
I am holding out for the Jimmy Hoffa model...
Return to Kickstarter/Crowd Funding Projects
